Salta al contenuto principale
VTech Kidizoom Camera Connect Front Case Replacement
Cosa ti serve
  1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: passo 1, immagine 1 di 2 VTech Kidizoom Camera Connect Front Case Replacement, Front Case: passo 1, immagine 2 di 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Front Case Replacement: passo 2, immagine 1 di 2 VTech Kidizoom Camera Connect Front Case Replacement: passo 2, immagine 2 di 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Front Case Replacement: passo 3, immagine 1 di 3 VTech Kidizoom Camera Connect Front Case Replacement: passo 3, immagine 2 di 3 VTech Kidizoom Camera Connect Front Case Replacement: passo 3, immagine 3 di 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Front Case Replacement: passo 4, immagine 1 di 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
Conclusione
Nick Foster
Membro da: 02/14/16
324 Reputazione
1 Guida realizzata
USF Tampa, Team 6-4, Eyestone Spring 2016 Membro di USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 24
Tutti i Tempi: 4,626
