Salta al contenuto principale
VTech InnoTab Max Screen Replacement
Cosa ti serve
  1. VTech InnoTab Max Screen Replacement, Cover: passo 1, immagine 1 di 3 VTech InnoTab Max Screen Replacement, Cover: passo 1, immagine 2 di 3 VTech InnoTab Max Screen Replacement, Cover: passo 1, immagine 3 di 3
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Screen Replacement: passo 2, immagine 1 di 3 VTech InnoTab Max Screen Replacement: passo 2, immagine 2 di 3 VTech InnoTab Max Screen Replacement: passo 2, immagine 3 di 3
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
  3. VTech InnoTab Max Screen Replacement: passo 3, immagine 1 di 2 VTech InnoTab Max Screen Replacement: passo 3, immagine 2 di 2
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Screen Replacement: passo 4, immagine 1 di 2 VTech InnoTab Max Screen Replacement: passo 4, immagine 2 di 2
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
  5. VTech InnoTab Max Screen Replacement, Battery: passo 5, immagine 1 di 1
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
  6. VTech InnoTab Max Screen Replacement: passo 6, immagine 1 di 3 VTech InnoTab Max Screen Replacement: passo 6, immagine 2 di 3 VTech InnoTab Max Screen Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
  7. VTech InnoTab Max Screen Replacement: passo 7, immagine 1 di 3 VTech InnoTab Max Screen Replacement: passo 7, immagine 2 di 3 VTech InnoTab Max Screen Replacement: passo 7, immagine 3 di 3
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
  8. VTech InnoTab Max Screen Replacement: passo 8, immagine 1 di 1
    • The battery is now fully disconnected.
  9. VTech InnoTab Max Screen Replacement, Screen: passo 9, immagine 1 di 2 VTech InnoTab Max Screen Replacement, Screen: passo 9, immagine 2 di 2
    • In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
    • To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
  10. VTech InnoTab Max Screen Replacement: passo 10, immagine 1 di 3 VTech InnoTab Max Screen Replacement: passo 10, immagine 2 di 3 VTech InnoTab Max Screen Replacement: passo 10, immagine 3 di 3
    • Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
  11. VTech InnoTab Max Screen Replacement: passo 11, immagine 1 di 3 VTech InnoTab Max Screen Replacement: passo 11, immagine 2 di 3 VTech InnoTab Max Screen Replacement: passo 11, immagine 3 di 3
    • In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
    • Be careful not to tear the film when pulling.
  12. VTech InnoTab Max Screen Replacement: passo 12, immagine 1 di 2 VTech InnoTab Max Screen Replacement: passo 12, immagine 2 di 2
    • Once unclipped from the motherboard the screen should be entirely free from the device
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S5-G5, Lacy Spring 2017 Membro di USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Membri
10 Guide realizzate
5Commenti sulla guida
Where can I buy a screen
Damien Hennigan - Replica
Where can I buy a screen? Can't find any sites that sell the innotab Max screens.
i can not seem to find a replacement screen online, where can i buy one? Innotab Max from Vtech… HELP please..
fanny_muller - Replica
Hello, where can i buy a KIDICOM MAX Rose Screen. Our daughter here is broken!.thanks a lot!
hans.depre@gmail.com
Hans Depre - Replica
bonjour je cherche a raplasser l ecran du kidicom max car le mien ne salume plus pas merci
theobald - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 5,544
