Salta al contenuto principale
VTech InnoTab 2 Backup Battery Replacement
Cosa ti serve
  1. VTech InnoTab 2 Backup Battery Replacement, Backup Battery: passo 1, immagine 1 di 3 VTech InnoTab 2 Backup Battery Replacement, Backup Battery: passo 1, immagine 2 di 3 VTech InnoTab 2 Backup Battery Replacement, Backup Battery: passo 1, immagine 3 di 3
    • The CR2032 compartment is located on bottom left corner on the backside of the device.
    • Unscrew the single 4 mm Phillip screw and slide the compartment cover off.
    • The 4 mm Phillip screw will not completely screw out of the cover.
  2. VTech InnoTab 2 Backup Battery Replacement: passo 2, immagine 1 di 3 VTech InnoTab 2 Backup Battery Replacement: passo 2, immagine 2 di 3 VTech InnoTab 2 Backup Battery Replacement: passo 2, immagine 3 di 3
    • Gently remove the CR2032 battery with your fingers.
    • A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
Conclusione
USF Tampa, Team S1-G85, Cagle Fall 2017 Membro di USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 476
