Salta al contenuto principale
VTech CS6719-2 Speaker Replacement
Cosa ti serve
  1. VTech CS6719-2 Speaker Replacement, Battery: passo 1, immagine 1 di 2 VTech CS6719-2 Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Speaker Replacement: passo 2, immagine 1 di 1
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Speaker Replacement: passo 3, immagine 1 di 1
    • Unplug the battery input cable.
  4. VTech CS6719-2 Speaker Replacement: passo 4, immagine 1 di 1
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Speaker Replacement, Circuit Board: passo 5, immagine 1 di 2 VTech CS6719-2 Speaker Replacement, Circuit Board: passo 5, immagine 2 di 2
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Speaker Replacement: passo 6, immagine 1 di 1
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Speaker Replacement: passo 7, immagine 1 di 2 VTech CS6719-2 Speaker Replacement: passo 7, immagine 2 di 2
    • Remove the two 9mm screws located inside the back cover at the top.
  8. VTech CS6719-2 Speaker Replacement, Speaker: passo 8, immagine 1 di 1
    • Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
    • The clip is loose, it could fall out.
  9. VTech CS6719-2 Speaker Replacement: passo 9, immagine 1 di 1
    • Lift speaker out.
  10. VTech CS6719-2 Speaker Replacement: passo 10, immagine 1 di 1
    • Heat up solder joint on the circuit board where the speaker wires are connected.
  11. VTech CS6719-2 Speaker Replacement: passo 11, immagine 1 di 1
Conclusione
IUPUI, Team 1-4, Baechle Spring 2016 Membro di IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Membri
16 Guide realizzate
2 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 710
