Salta al contenuto principale
VTech Baby's Learning Laptop Battery and Rear Panel Replacement
Cosa ti serve
  1. VTech Baby's Learning Laptop Battery and Rear Panel Replacement, Battery and Rear Panel: passo 1, immagine 1 di 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Battery and Rear Panel Replacement: passo 2, immagine 1 di 1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Battery and Rear Panel Replacement: passo 3, immagine 1 di 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Battery and Rear Panel Replacement: passo 4, immagine 1 di 2 VTech Baby's Learning Laptop Battery and Rear Panel Replacement: passo 4, immagine 2 di 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
Conclusione
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro di USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,218
