Salta al contenuto principale
VTech Baby's Learning Laptop Mode Switch Replacement
Cosa ti serve
  1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: passo 1, immagine 1 di 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
    Chiedi a FixBot
  2. VTech Baby's Learning Laptop Mode Switch Replacement: passo 2, immagine 1 di 1
    • Remove the battery door.
    • Take out the batteries.
    Chiedi a FixBot
  3. VTech Baby's Learning Laptop Mode Switch Replacement: passo 3, immagine 1 di 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
    Chiedi a FixBot
  4. VTech Baby's Learning Laptop Mode Switch Replacement: passo 4, immagine 1 di 2 VTech Baby's Learning Laptop Mode Switch Replacement: passo 4, immagine 2 di 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
    Chiedi a FixBot
  5. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: passo 5, immagine 1 di 2 VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: passo 5, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
    Chiedi a FixBot
  6. VTech Baby's Learning Laptop Mode Switch Replacement: passo 6, immagine 1 di 3 VTech Baby's Learning Laptop Mode Switch Replacement: passo 6, immagine 2 di 3 VTech Baby's Learning Laptop Mode Switch Replacement: passo 6, immagine 3 di 3
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
    Chiedi a FixBot
  7. VTech Baby's Learning Laptop Mode Switch Replacement: passo 7, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
    • Five 7.3mm
    • Two 6.0mm
    Chiedi a FixBot
  8. VTech Baby's Learning Laptop Mode Switch Replacement: passo 8, immagine 1 di 1
    • Once the screws have been removed, the mode switch assembly can be removed easily.
    • Take care not to misplace the spring indicated in the picture.
    • You need this spring to find a matching replacement if it is in anyway damaged.
    Chiedi a FixBot
Conclusione
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro di USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 49
Tutti i Tempi: 776
