Salta al contenuto principale
VENSTAR Taco Speaker Replacement Replacement
Cosa ti serve
  1. VENSTAR Taco Speaker Replacement Replacement, VENSTAR Taco Disassembly: passo 1, immagine 1 di 3 VENSTAR Taco Speaker Replacement Replacement, VENSTAR Taco Disassembly: passo 1, immagine 2 di 3 VENSTAR Taco Speaker Replacement Replacement, VENSTAR Taco Disassembly: passo 1, immagine 3 di 3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. VENSTAR Taco Speaker Replacement Replacement: passo 2, immagine 1 di 2 VENSTAR Taco Speaker Replacement Replacement: passo 2, immagine 2 di 2
    • Repeat the previous step on the opposite side to remove the other outer casing.
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  3. VENSTAR Taco Speaker Replacement Replacement: passo 4, immagine 1 di 2 VENSTAR Taco Speaker Replacement Replacement: passo 4, immagine 2 di 2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  4. VENSTAR Taco Speaker Replacement Replacement: passo 5, immagine 1 di 2 VENSTAR Taco Speaker Replacement Replacement: passo 5, immagine 2 di 2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
  5. VENSTAR Taco Speaker Replacement Replacement, Logic Board Replacement: passo 6, immagine 1 di 1
    • Remove the rubber covering from the buttons.
  6. VENSTAR Taco Speaker Replacement Replacement: passo 7, immagine 1 di 3 VENSTAR Taco Speaker Replacement Replacement: passo 7, immagine 2 di 3 VENSTAR Taco Speaker Replacement Replacement: passo 7, immagine 3 di 3
    • Remove the black fabric covering the logic board.
  7. VENSTAR Taco Speaker Replacement Replacement: passo 8, immagine 1 di 2 VENSTAR Taco Speaker Replacement Replacement: passo 8, immagine 2 di 2
    • Move the battery out of the way of the connector.
  8. VENSTAR Taco Speaker Replacement Replacement: passo 9, immagine 1 di 2 VENSTAR Taco Speaker Replacement Replacement: passo 9, immagine 2 di 2
    • Undo the connector of the flat white ribbon between the switches and the logic board.
  9. VENSTAR Taco Speaker Replacement Replacement: passo 10, immagine 1 di 1
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
  10. VENSTAR Taco Speaker Replacement Replacement: passo 11, immagine 1 di 3 VENSTAR Taco Speaker Replacement Replacement: passo 11, immagine 2 di 3 VENSTAR Taco Speaker Replacement Replacement: passo 11, immagine 3 di 3
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
  11. VENSTAR Taco Speaker Replacement Replacement, Speaker Replacement: passo 12, immagine 1 di 2 VENSTAR Taco Speaker Replacement Replacement, Speaker Replacement: passo 12, immagine 2 di 2
    • Using the Ph1 screwdriver, unscrew both of the 2.5mm screws on either side of the speakers.
    • The screws are glued in and may require the curved tweezers to pull all the way out.
  12. VENSTAR Taco Speaker Replacement Replacement: passo 13, immagine 1 di 1
    • Using a metal spudger, carefully wedge out the speakers from the casing.
    • Repeat this step for the removal of the other speaker.
    • Speakers are glued into the casing beyond being screwed and require some care to remove.
  13. VENSTAR Taco Speaker Replacement Replacement: passo 14, immagine 1 di 1
    • Using a portable soldering iron, melt the solder on the black speaker wires on the logic board.
    • Soldering uses hot metal and can burn you!
Conclusione
Solder your replacement speakers back to mother board, then to reassemble your device, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 312
