Salta al contenuto principale
Using the 3DS's Safe Mode
  1. Using the 3DS's Safe Mode, Booting safe mode: passo 1, immagine 1 di 1
    • Ensure the console is powered off
    • Hold the (L) + (R) + (A) + (D-Pad Up) buttons
    • Keep these buttons held down until the console boots in the next step
    • While still holding the other buttons, press the power button
  2. Using the 3DS's Safe Mode, Updating the System: passo 2, immagine 1 di 3 Using the 3DS's Safe Mode, Updating the System: passo 2, immagine 2 di 3 Using the 3DS's Safe Mode, Updating the System: passo 2, immagine 3 di 3
    • You should boot into a "system update" screen. Click OK and accept the prompts
    • If there's no working internet connection configured on your 3ds, you'll have the option to set one up now
  3. Using the 3DS's Safe Mode: passo 3, immagine 1 di 1
    • When the update finishes, the console will automatically turn off
Conclusione
If your issue persists after following this guide, a system format may fix it. Or, if you'd prefer to keep your data, you can ask a question
darth mango
Membro da: 03/13/23
2.306 Reputazione
3 Guide realizzate
Kid fixers Membro di Kid fixers
Community
169 Membri
225 Guide realizzate
4 Commenti
Does this work on old family 3ds?
maxxy waxxy - Replica
Works on every 3ds and 2ds model
darth mango -
Hello Darth mango. I have had my 3ds xl (red btw) since 2016. It stopped working in 19 and I gave up. Never knew why, but when I tried this it didn't work. I see u have a reputation for fixing this stuff and I followed EVERY one of our guides. Nothing works. Should I just just go get it repaired, because NOTHING will work, even this.
Jahasen :D - Replica
Can you post a question about this? I try to avoid troubleshooting in comments as opposed to the forum made for it. Remember to include any symptoms (what happens when you plug it in, try to turn it on, etc.) as well as what fixes you've already tried. The better the info you give us, the better we'll be able to help. :D
darth mango -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 118
Tutti i Tempi: 3,751
