Salta al contenuto principale
Using a Floor Jack
Cosa ti serve
  1. Using a Floor Jack, Using a Floor Jack: passo 1, immagine 1 di 2 Using a Floor Jack, Using a Floor Jack: passo 1, immagine 2 di 2
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
  2. Using a Floor Jack, Using floor jack to lift car.: passo 2, immagine 1 di 1
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
  3. Using a Floor Jack: passo 3, immagine 1 di 1
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
  4. Using a Floor Jack: passo 4, immagine 1 di 1
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
Conclusione
Altre 8 persone hanno completato questa guida.
Cal Poly, Team 24-27, Regan Fall 2012 Membro di Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 62
Ultimi 30 Giorni: 221
Tutti i Tempi: 40,007
