Introduzione
The Apple Pro Speakers (made by harman kardon) are a great piece of technology. They were specially designed for the iMac G4 and the Power Mac G4 MDD (mirrored door drives) series. Those computers had a special connector which supplied both – an audio signal and power – to the speakers.
There are some guides which explain how to connect the speakers using a 3.5 mm jack, but this will never be a real solution as these speakers need to be driven by a real amp – and not the line-out of a computer or other audio device.
As Griffin iFire converters are expensive and hard to get, this guide relies on a class-d amp, which means that you can revive the speakers for about 40 US dollars.
Cosa ti serve
This image shows the complete setup with which you will end up. With a little bit of work you can soon enjoy the clear sound of true harman kardon speakers.
Please note: This guide will destroy the original cable/connector which is used to connect the Apple Pro Speakers to an iMac, Power Mac or the Griffin iFire.
Please also note that – as with every electronical repair or modification guide – you alone are responsible for your own health and the health of others. Also be aware that you alone are responsible for any damaged electronic equipment.
Now you will need to find out the proper polarity of the speakers, i.e. which cable is negative (-) and which is positive (+).
Unfortunately – at the time where I did this conversion – I did not photograph the cable colors. But there is an easy trick to find out the polarity:
In this image you see two banana plugs and a AA battery. Just imagine these are two stripped wires from one of the speaker cables.
Now connect one wire to the negative terminal (-) and the other to the positive terminal (+) of the AA battery.
If the speaker cone bulges out (left image), you've got the proper polarity. You now know that the wire on the positive terminal of the AA battery is your "+" wire, i.e. it will connect with the "+" output of your amp.
If the speaker cone moves in (right image), the polarity is reversed. You now know that the wire on the negative terminal of the AA battery would be your "+" wire, i.e. it will connect with the "+" output of your amp.
You are almost done. Now properly connect the speaker cables/banana plugs with your amp. Connect your Mac or PC or some other audio device with the amp and enjoy your old new Apple Pro Speakers.
Please note that the Apple Pro Speakers don't sound too loud, but that's by design. Still, their sound is very clean and detailed (on a class-d amp).
Altre 39 persone hanno completato questa guida.
48 Commenti
Good guide. I'm doing the same thing with a pair of these speakers, but I think I'll use new cables soldered to the speaker terminals.
One quibble though. I believe the correct term for the wire covering is "insulation", not isolation, and in step 9, you "insulate" the wires, rather than isolate.
Thanks chuck, I have corrected the wire covering term :)
rafael -
Will this amplifier work for my Apple Pro speakers?
Should work. Not the 'best' amp out there, but same tripath chip as most other class-d amps on the market.
rafael -
