Salta al contenuto principale
Urge Basics Soundbrick Speaker Woofer Replacement
Cosa ti serve
  1. Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: passo 1, immagine 1 di 3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: passo 1, immagine 2 di 3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: passo 1, immagine 3 di 3
    • Flip the speaker upside down.
    • Unscrew the middle screw with a Philips #1 screwdriver.
  2. Urge Basics Soundbrick Speaker Woofer Replacement: passo 2, immagine 1 di 2 Urge Basics Soundbrick Speaker Woofer Replacement: passo 2, immagine 2 di 2
    • Peel off the two gray tabs to expose the four inner Philips #1 screws.
  3. Urge Basics Soundbrick Speaker Woofer Replacement: passo 3, immagine 1 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 3, immagine 2 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 3, immagine 3 di 3
    • Unscrew all four screws with a Philips #1 screwdriver.
    • The screws are deep and can be difficult to take out.
  4. Urge Basics Soundbrick Speaker Woofer Replacement: passo 4, immagine 1 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 4, immagine 2 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 4, immagine 3 di 3
    • Flip the speaker so that the ports are facing up.
    • Unfold the speaker's cover away from the body.
  5. Urge Basics Soundbrick Speaker Woofer Replacement: passo 5, immagine 1 di 2 Urge Basics Soundbrick Speaker Woofer Replacement: passo 5, immagine 2 di 2
    • Remove the two Phillips #1 screws found on each side of the battery compartment.
    • Removal of battery compartment is necessary to prevent electric shock when replacing the woofer.
  6. Urge Basics Soundbrick Speaker Woofer Replacement: passo 6, immagine 1 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 6, immagine 2 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 6, immagine 3 di 3
    • Disconnect the battery connectors attached to the circuit board by unplugging them.
  7. Urge Basics Soundbrick Speaker Woofer Replacement: passo 7, immagine 1 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 7, immagine 2 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 7, immagine 3 di 3
    • Disconnect the ribbon cable from the battery by carefully pulling it out.
    • Remove the battery compartment.
  8. Urge Basics Soundbrick Speaker Woofer Replacement: passo 8, immagine 1 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 8, immagine 2 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 8, immagine 3 di 3
    • Disconnect the adjacent connector from the main circuit board.
  9. Urge Basics Soundbrick Speaker Woofer Replacement: passo 9, immagine 1 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 9, immagine 2 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 9, immagine 3 di 3
    • Disconnect the woofer's two connectors from the main circuit board.
  10. Urge Basics Soundbrick Speaker Woofer Replacement: passo 10, immagine 1 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 10, immagine 2 di 3 Urge Basics Soundbrick Speaker Woofer Replacement: passo 10, immagine 3 di 3
    • Remove the two Phillips #1 screws keeping each woofer in place.
    • Carefully remove the woofers and replace them with new ones.
Conclusione
Itzel Urueta
Membro da: 04/28/17
125 Reputazione
1 Guida realizzata
UC Davis, Team S2-G4, Cole Spring 2017 Membro di UC Davis, Team S2-G4, Cole Spring 2017
UCD-COLE-S17S2G4
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 862
