Salta al contenuto principale
Upper Board Removal
Cosa ti serve
  1. Upper Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: passo 1, immagine 1 di 1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Upper Board Removal: passo 2, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Upper Board Removal: passo 3, immagine 1 di 3 Upper Board Removal: passo 3, immagine 2 di 3 Upper Board Removal: passo 3, immagine 3 di 3
    • Grab the top shell of the mouse and lift up to remove.
  4. Upper Board Removal: passo 4, immagine 1 di 1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Upper Board Removal: passo 5, immagine 1 di 2 Upper Board Removal: passo 5, immagine 2 di 2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Upper Board Removal, Top Shell: passo 6, immagine 1 di 1
    • Remove the 5 mm round head screw holding the middle piece to the top piece.
    • The outermost shell will now separate from the middle structure.
  7. Upper Board Removal, Upper Board: passo 7, immagine 1 di 1
    • Using the Phillips #1 screwdriver, unscrew the 5 mm black flat head screw that's securing the scroll wheel cage.
  8. Upper Board Removal: passo 8, immagine 1 di 2 Upper Board Removal: passo 8, immagine 2 di 2
    • Pinch the cage to release snaps. You can now pull the cage off.
  9. Upper Board Removal: passo 9, immagine 1 di 1
    • Remove the screw holding the circuit board down.
    • The board will now pop off easily.
Conclusione
Altre 2 persone hanno completato questa guida.
David
Membro da: 01/16/13
1.181 Reputazione
4 Guide realizzate
Cal Poly, Team 18-36, Regan Winter 2013 Membro di Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Membri
30 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 845
