Salta al contenuto principale
Unsticking SteelSeries Nimbus Triggers
Cosa ti serve
  1. Unsticking SteelSeries Nimbus Triggers, Unsticking SteelSeries Nimbus Triggers: passo 1, immagine 1 di 1
    • When your triggers get stickier than the Cheeto® dust on your hands it might be time for an intervention.
  2. Unsticking SteelSeries Nimbus Triggers: passo 2, immagine 1 di 2 Unsticking SteelSeries Nimbus Triggers: passo 2, immagine 2 di 2
    • Start off by removing the four TR9 Torx Security screws on the back of the controller.
  3. Unsticking SteelSeries Nimbus Triggers: passo 3, immagine 1 di 3 Unsticking SteelSeries Nimbus Triggers: passo 3, immagine 2 di 3 Unsticking SteelSeries Nimbus Triggers: passo 3, immagine 3 di 3
    • The two screws on the top are further inset than the others. You can use the iFixit 1/4" to 4 mm Driver Adapter as an extender.
  4. Unsticking SteelSeries Nimbus Triggers: passo 4, immagine 1 di 2 Unsticking SteelSeries Nimbus Triggers: passo 4, immagine 2 di 2
    • The case is now open, but it's still held together by two clips on the top.
  5. Unsticking SteelSeries Nimbus Triggers: passo 5, immagine 1 di 3 Unsticking SteelSeries Nimbus Triggers: passo 5, immagine 2 di 3 Unsticking SteelSeries Nimbus Triggers: passo 5, immagine 3 di 3
    • Apply a gentle twisting motion to separate the first clip.
    • Twist in the other direction to separate the second clip.
    • The top is now free!
  6. Unsticking SteelSeries Nimbus Triggers: passo 6, immagine 1 di 3 Unsticking SteelSeries Nimbus Triggers: passo 6, immagine 2 di 3 Unsticking SteelSeries Nimbus Triggers: passo 6, immagine 3 di 3
    • Be mindful of the three cables still connecting the two halves.
  7. Unsticking SteelSeries Nimbus Triggers: passo 7, immagine 1 di 2 Unsticking SteelSeries Nimbus Triggers: passo 7, immagine 2 di 2
    • Here's our problem, the rubber pad has fallen off of the plastic stop leaving only the glue behind.
    • The rubber pad should still be in the controller somewhere (happy hunting) or if you're not in the mood for hide and seek any kind of foam will work as a replacement.
Conclusione
Altre 8 persone hanno completato questa guida.
Jonathan
Membro da: 03/13/13
464 Reputazione
2 Guide realizzate
4 Commenti
Great, concise fix instructions!
Brian Pippen - Replica
My nimbus started to have sticky triggers. I could not believe that I had found this solution! Awesome!
Max-Heinrich Laves - Replica
Hi, I have a Nimbus + controller. It's seems to have clips at the back too. Any advice on how to open it?
Sean Hudson - Replica
Greetings, someone who can help me where I can get the joystick, original remote control ?
Excellent information
bryan Andino - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 45
Tutti i Tempi: 6,134
