Salta al contenuto principale
Uniden UTAB71 Screen Replacement
Cosa ti serve
  1. Uniden UTAB71 Screen Replacement, Screen: passo 1, immagine 1 di 2 Uniden UTAB71 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Use a pry tool to undo the clips that attach the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Screen Replacement: passo 2, immagine 1 di 2 Uniden UTAB71 Screen Replacement: passo 2, immagine 2 di 2
    • Lift off the black clip connecting the first power ribbon to the motherboard
    • Undo the clips off the second power ribbon connecting the screen to the motherboard.
  3. Uniden UTAB71 Screen Replacement: passo 3, immagine 1 di 3 Uniden UTAB71 Screen Replacement: passo 3, immagine 2 di 3 Uniden UTAB71 Screen Replacement: passo 3, immagine 3 di 3
    • Slowly remove the screen component off the tablet by clipping the screen from the tablet outine
    • Do not apply too much pressure on the tablet casing.
Conclusione
Ryan Jewell
Membro da: 10/20/16
422 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 5-4, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 337
