Salta al contenuto principale
Uniden UTAB71 Camera Replacement
Cosa ti serve
  1. Uniden UTAB71 Camera Replacement, Camera: passo 1, immagine 1 di 2 Uniden UTAB71 Camera Replacement, Camera: passo 1, immagine 2 di 2
    • Use a plastic pry tool to separate the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Camera Replacement: passo 2, immagine 1 di 2 Uniden UTAB71 Camera Replacement: passo 2, immagine 2 di 2
    • Use a credit card to lift the battery off the back of the tablet.
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery is glued onto the back of the tablet so make sure to apply as much pressure as needed
  3. Uniden UTAB71 Camera Replacement: passo 3, immagine 1 di 1
    • Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
  4. Uniden UTAB71 Camera Replacement: passo 4, immagine 1 di 3 Uniden UTAB71 Camera Replacement: passo 4, immagine 2 di 3 Uniden UTAB71 Camera Replacement: passo 4, immagine 3 di 3
    • Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
    • Place the plastic pry tool under the camera component and lift it off the tablet.
Conclusione
Ryan Jewell
Membro da: 10/20/16
422 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 5-4, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 166
