Salta al contenuto principale
Uniden TCX905 Earpiece Speaker Replacement
Cosa ti serve
  1. Uniden TCX905 Earpiece Speaker Replacement, Battery Cover: passo 1, immagine 1 di 2 Uniden TCX905 Earpiece Speaker Replacement, Battery Cover: passo 1, immagine 2 di 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Earpiece Speaker Replacement, Battery Pack: passo 2, immagine 1 di 2 Uniden TCX905 Earpiece Speaker Replacement, Battery Pack: passo 2, immagine 2 di 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Earpiece Speaker Replacement, Back Shell: passo 3, immagine 1 di 2 Uniden TCX905 Earpiece Speaker Replacement, Back Shell: passo 3, immagine 2 di 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Earpiece Speaker Replacement: passo 4, immagine 1 di 3 Uniden TCX905 Earpiece Speaker Replacement: passo 4, immagine 2 di 3 Uniden TCX905 Earpiece Speaker Replacement: passo 4, immagine 3 di 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Earpiece Speaker Replacement: passo 5, immagine 1 di 3 Uniden TCX905 Earpiece Speaker Replacement: passo 5, immagine 2 di 3 Uniden TCX905 Earpiece Speaker Replacement: passo 5, immagine 3 di 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Earpiece Speaker Replacement, Circuit Board: passo 6, immagine 1 di 2 Uniden TCX905 Earpiece Speaker Replacement, Circuit Board: passo 6, immagine 2 di 2
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
  7. Uniden TCX905 Earpiece Speaker Replacement: passo 7, immagine 1 di 3 Uniden TCX905 Earpiece Speaker Replacement: passo 7, immagine 2 di 3 Uniden TCX905 Earpiece Speaker Replacement: passo 7, immagine 3 di 3
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
  8. Uniden TCX905 Earpiece Speaker Replacement, Earpiece Speaker: passo 8, immagine 1 di 2 Uniden TCX905 Earpiece Speaker Replacement, Earpiece Speaker: passo 8, immagine 2 di 2
    • Place circuit board gently on the back shell with the earpiece facing up
  9. Uniden TCX905 Earpiece Speaker Replacement: passo 9, immagine 1 di 3 Uniden TCX905 Earpiece Speaker Replacement: passo 9, immagine 2 di 3 Uniden TCX905 Earpiece Speaker Replacement: passo 9, immagine 3 di 3
    • Pry speaker gently from setting using tweezers
    • Cut red and black wires near the soldering
Conclusione
Gary Pence
Membro da: 03/26/14
807 Reputazione
8 Guide realizzate
Clemson, Team 1-1, Benson Spring 2014 Membro di Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 483
