Introduzione
The back speaker is where the ring of the phone comes from.
Cosa ti serve
Starting from the top of the cover, slide down and away from the phone with your thumb
Lift battery cover off of batter and place it to the side
Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
Place battery pack to the side
Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
Lay the back shell with the inside facing up
To remove the speaker guard, first remove the 7mm screw from inside the back shell
