Salta al contenuto principale
Uniden Guardian G955 Speaker Replacement
Cosa ti serve
  1. Uniden Guardian G955 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Using a J1 Philips head screwdriver, unscrew all four 6.1 mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. Uniden Guardian G955 Speaker Replacement: passo 2, immagine 1 di 1
    • Using a metal spudger, open the monitor from the corner. Slowly slide the spudger around the case to prop open the case.
    Chiedi a FixBot
    Aggiungi Commento
  3. Uniden Guardian G955 Speaker Replacement: passo 3, immagine 1 di 2 Uniden Guardian G955 Speaker Replacement: passo 3, immagine 2 di 2
    • Locate the circular speaker in one of the corners of the device. To release the speaker, pinch the metal fastener together and lift it off of the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  4. Uniden Guardian G955 Speaker Replacement: passo 4, immagine 1 di 2 Uniden Guardian G955 Speaker Replacement: passo 4, immagine 2 di 2
    • Follow the speaker towards the input on the motherboard. Pull it from the motherboard horizontally for it to loosen easier.
    • You may have to wiggle the head of the wire to efficiently remove it from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Uniden Guardian G955 Speaker Replacement: passo 5, immagine 1 di 2 Uniden Guardian G955 Speaker Replacement: passo 5, immagine 2 di 2
    • Using an angled ESD tweezer, pull back on the black clamp with one hand while lifting the wires with the other hand.
    • You will have to apply a large amount of force on the black clamp to get it to move enough to lift the two wires out of it.
    Chiedi a FixBot
    Aggiungi Commento
  6. Uniden Guardian G955 Speaker Replacement: passo 6, immagine 1 di 1
    • Carefully lift the speaker and all of the components in the speaker socket off of the monitor.
    • The speaker's film may be glued down to the socket where it's held. If this is the case, you must pull it all off and carefully clean it so that you may add the new speaker and ensure it fits with no leftover glue residue from the previous speaker.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Fabian Demiro
Membro da: 10/06/16
177 Reputazione
Una guida realizzata
USF Tampa, Team 1-1, Nance Fall 2016 Membro di USF Tampa, Team 1-1, Nance Fall 2016
USFT-NANCE-F16S1G1
3 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 27
Tutti i Tempi: 573
