Uniden EXP371 900 MHz Cordless Phone.
  • Uniden EXP371 900 MHz Cordless Phone.
  • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
Aggiungi Commento
Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
  • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
  • Next remove the battery by pulling on the connector.
Aggiungi Commento
  • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
  • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
Aggiungi Commento
  • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
  • Once you have removed the five screws you may lift the motherboard off of the front case.
  • At this point you may also remove the dial pad. It simply lifts off.
  • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
  • The whole phone is now disassembled at this point.
Aggiungi Commento
  • After following the teardown guide. Take the bottom case and locate the antenna at the top of the phone.
  • Lift the bottom of the the antenna with the aid of a tool (these tweezers work well) and push the antenna inside the phone to remove it.
  • To reassemble the phone, follow the steps in the reverse order.
Aggiungi Commento
Conclusione
Eric Rodrigues
Membro da: 16/10/2014
313 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Membro di UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 791
