Introduzione
In this guide, you will learn how to dissemble the the base of Uniden D1688. You will learn how to use the spudger to open the case.
Cosa ti serve
Unplug the phone from the base by detaching the RJ-11 plug.
Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
