Salta al contenuto principale
Uniden D1688 Base Replacement
Cosa ti serve
  1. Uniden D1688 Base Replacement, Uniden D1688 Base Replacement: passo 1, immagine 1 di 1
    • Unplug the phone from the base by detaching the RJ-11 plug.
    • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
  2. Uniden D1688 Base Replacement: passo 2, immagine 1 di 2 Uniden D1688 Base Replacement: passo 2, immagine 2 di 2
    • Using the spudger, separate the top shell of the base from the bottom shell from the base.
    • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
    • Lift the top shell off the bottom, and you have successfully opened the phone base.
Conclusione
justin
Membro da: 01/26/15
419 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 276
