Salta al contenuto principale
Uniden D1483-3BK Handset Keypad Replacement
Cosa ti serve
  1. Uniden D1483-3BK Handset Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Handset Keypad Replacement: passo 2, immagine 1 di 2 Uniden D1483-3BK Handset Keypad Replacement: passo 2, immagine 2 di 2
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Handset Keypad Replacement: passo 3, immagine 1 di 1
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Handset Keypad Replacement, Handset Case: passo 4, immagine 1 di 2 Uniden D1483-3BK Handset Keypad Replacement, Handset Case: passo 4, immagine 2 di 2
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Handset Keypad Replacement: passo 5, immagine 1 di 3 Uniden D1483-3BK Handset Keypad Replacement: passo 5, immagine 2 di 3 Uniden D1483-3BK Handset Keypad Replacement: passo 5, immagine 3 di 3
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Handset Keypad Replacement: passo 6, immagine 1 di 2 Uniden D1483-3BK Handset Keypad Replacement: passo 6, immagine 2 di 2
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Handset Keypad Replacement: passo 7, immagine 1 di 2 Uniden D1483-3BK Handset Keypad Replacement: passo 7, immagine 2 di 2
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Handset Keypad Replacement, Handset Keypad: passo 8, immagine 1 di 1
    • Remove the rubber keypad from the front half of the handset case.
    • The keypad comes in two separate pieces.
Conclusione
Altre 6 persone hanno completato questa guida.
Arbitrary Name
Membro da: 01/28/15
1.083 Reputazione
4 Guide realizzate
Penn State, Team 1-8, Kaschak Winter 2015 Membro di Penn State, Team 1-8, Kaschak Winter 2015
PSU-KASCHAK-W15S1G8
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 209
