Salta al contenuto principale
Unbranded UB-15MS10 Battery Replacement
Cosa ti serve
  1. Unbranded UB-15MS10 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
  3. Unbranded UB-15MS10 Battery Replacement: passo 3, immagine 1 di 2 Unbranded UB-15MS10 Battery Replacement: passo 3, immagine 2 di 2
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Battery Replacement: passo 4, immagine 1 di 1
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the tape that is holding the battery in place.
  6. Unbranded UB-15MS10 Battery Replacement: passo 6, immagine 1 di 1
    • Cut the wires connecting the battery to the device using a pair of wire cutters.
  7. Unbranded UB-15MS10 Battery Replacement: passo 7, immagine 1 di 1
    • Carefully remove the battery, making sure that all wires are disconnected.
  8. Unbranded UB-15MS10 Battery Replacement: passo 8, immagine 1 di 1
    • Splice the new battery with the red, white, and black wires connected to the motherboard.
Conclusione
To reassemble your device, follow directions 1-7 in reverse order.
Altre 3 persone hanno completato questa guida.
Un commento
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,307
