Salta al contenuto principale
Ubuntu Linux Fixing Crackling/Glitching Audio
  1. Ubuntu Linux Fixing Crackling/Glitching Audio, Ubuntu Linux Fixing Crackling/Glitching Audio: passo 1, immagine 1 di 1
    • Open your terminal and type sudo nano /usr/share/pipewire/pipewire-pulse.conf
    • Press enter. If you are prompted for your password, enter your device's password and press enter.
    • You now have access to your pipewire settings!
  2. Ubuntu Linux Fixing Crackling/Glitching Audio: passo 2, immagine 1 di 1
    • Press Ctrl + W to search for pulse.min.quantum and press Enter.
    • You should find a line that says #pulse.min.quantum = 128/48000 # 2.7ms
    • Remove the first '#' at the beginning of the line and change the number 128 to 256.
    • To save your new settings, press Ctrl + X, then Y, then Enter.
  3. Ubuntu Linux Fixing Crackling/Glitching Audio: passo 3, immagine 1 di 1
    • Test your new settings to see if the crackling continues.
    • If the crackling is gone, great! If not, repeat the previous step but change the number 256 to 512. Then test again.
Conclusione
If you'd like to reverse the changes made in this guide, go through the steps again but change the new number to 128 and add a '#' back on the beginning of the line.
Lynx
Membro da: 01/04/25
639 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 124
Ultimi 30 Giorni: 358
Tutti i Tempi: 946
