Salta al contenuto principale
UTStarcom XV6700 Camera Replacement
Cosa ti serve
  1. UTStarcom XV6700 Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Press the on/off button on the top to power the phone off.
  2. UTStarcom XV6700 Camera Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
  3. UTStarcom XV6700 Camera Replacement: passo 3, immagine 1 di 3 UTStarcom XV6700 Camera Replacement: passo 3, immagine 2 di 3 UTStarcom XV6700 Camera Replacement: passo 3, immagine 3 di 3
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
  4. UTStarcom XV6700 Camera Replacement, Camera: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
  5. UTStarcom XV6700 Camera Replacement: passo 5, immagine 1 di 2 UTStarcom XV6700 Camera Replacement: passo 5, immagine 2 di 2
    • Use firm pressure to carefully pry off the cover with your fingers.
  6. UTStarcom XV6700 Camera Replacement: passo 6, immagine 1 di 1
    • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
  7. UTStarcom XV6700 Camera Replacement: passo 7, immagine 1 di 1
    • Gently pry off the camera flash circuit board with the spudger.
  8. UTStarcom XV6700 Camera Replacement: passo 8, immagine 1 di 1
    • Gently pry off the camera with the spudger.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 193
