Salta al contenuto principale
ULCO ntegrus PSV ventilator Battery Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
Cosa ti serve
    • Before disassembly, make sure the front wheel breaks are on.
    • Make sure ALL gas supplies are disconnected and the system has been purged, and make sure all electrical supplies have been disconnected.
  1. ULCO ntegrus PSV ventilator Battery Replacement: passo 4, immagine 1 di 1
    • With one hand on the ventilator removal handle and one holding the lower half of the ventilator, pull up firmly on the handle so that the mounting slides up the slots in the frame.
  2. ULCO ntegrus PSV ventilator Battery Replacement: passo 5, immagine 1 di 1
    • Pull the ventilator housing towards you so that the mounting tabs come out of the frame slots rest the ventilator housing on the plastic skirt at the rear of the workstation as shown in the photo.
  3. ULCO ntegrus PSV ventilator Battery Replacement, Battery: passo 6, immagine 1 di 1
    • Remove the main cover plate from the ventilator enclosure by removing all screws.
    • Disconnect the battery.
  4. ULCO ntegrus PSV ventilator Battery Replacement: passo 8, immagine 1 di 1
    • Remove the four pan head screws (SM0308P) holding down the battery plate (EV9109) and battery (EV9108) and remove the battery plate and battery.
  5. ULCO ntegrus PSV ventilator Battery Replacement: passo 9, immagine 1 di 1
    • Install the new battery in the same location and screw down the battery plate onto the battery plate spacers so that the battery is firmly held in place.
    • Reconnect the battery.
Conclusione
Preston Myers
Membro da: 04/09/20
493 Reputazione
4 Guide realizzate
Cal Poly, Team S7-G13, Paton Spring 2020 Membro di Cal Poly, Team S7-G13, Paton Spring 2020
CPSU-PATON-S20S7G13
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 67
