Salta al contenuto principale
UE BOOM 2 Micro-USB Port Replacement
Cosa ti serve
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: passo 1, immagine 1 di 2 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: passo 1, immagine 2 di 2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: passo 2, immagine 1 di 2 UE BOOM 2 Micro-USB Port Replacement: passo 2, immagine 2 di 2
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: passo 3, immagine 1 di 3 UE BOOM 2 Micro-USB Port Replacement: passo 3, immagine 2 di 3 UE BOOM 2 Micro-USB Port Replacement: passo 3, immagine 3 di 3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
    The rubber is glued to a hard plastic part of the case that is snapped in. Must remove the hard plastic that the rubber is attached to. Not just the rubber.
    Jordan Baxter (jbax92) - Replica
  4. UE BOOM 2 Micro-USB Port Replacement: passo 4, immagine 1 di 1
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: passo 5, immagine 1 di 3 UE BOOM 2 Micro-USB Port Replacement: passo 5, immagine 2 di 3 UE BOOM 2 Micro-USB Port Replacement: passo 5, immagine 3 di 3
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
Conclusione
Altre 7 persone hanno completato questa guida.
Alex Bahm
Membro da: 01/18/18
2.196 Reputazione
6 Guide realizzate
Cal Poly, Team S12-G5, Banghart Winter 2018 Membro di Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Membri
15 Guide realizzate
6 Commenti
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - Replica
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - Replica
i too am looking to find the replacement part
Liam Nicholls - Replica
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - Replica
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - Replica
I want to have the UE Boom 2
Fixed because it stopped charging while plugging my UE Boom 2
Shannon Leclair - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 102
Tutti i Tempi: 8,197
