Salta al contenuto principale
Turtle Beach Recon Controller Joystick Caps Replacement
Cosa ti serve
  1. Turtle Beach Recon Controller Joystick Caps Replacement, Back Plate: passo 1, immagine 1 di 3 Turtle Beach Recon Controller Joystick Caps Replacement, Back Plate: passo 1, immagine 2 di 3 Turtle Beach Recon Controller Joystick Caps Replacement, Back Plate: passo 1, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
    Chiedi a FixBot
  2. Turtle Beach Recon Controller Joystick Caps Replacement: passo 2, immagine 1 di 3 Turtle Beach Recon Controller Joystick Caps Replacement: passo 2, immagine 2 di 3 Turtle Beach Recon Controller Joystick Caps Replacement: passo 2, immagine 3 di 3
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
    Chiedi a FixBot
  3. Turtle Beach Recon Controller Joystick Caps Replacement, Face Plate: passo 3, immagine 1 di 2 Turtle Beach Recon Controller Joystick Caps Replacement, Face Plate: passo 3, immagine 2 di 2
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
    Chiedi a FixBot
  4. Turtle Beach Recon Controller Joystick Caps Replacement: passo 4, immagine 1 di 2 Turtle Beach Recon Controller Joystick Caps Replacement: passo 4, immagine 2 di 2
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
    Chiedi a FixBot
  5. Turtle Beach Recon Controller Joystick Caps Replacement: passo 5, immagine 1 di 3 Turtle Beach Recon Controller Joystick Caps Replacement: passo 5, immagine 2 di 3 Turtle Beach Recon Controller Joystick Caps Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
    Chiedi a FixBot
  6. Turtle Beach Recon Controller Joystick Caps Replacement, Joystick Caps: passo 6, immagine 1 di 2 Turtle Beach Recon Controller Joystick Caps Replacement, Joystick Caps: passo 6, immagine 2 di 2
    • Use your fingers to lift both of the joystick caps off of the motherboard.
    • Remove the joystick caps.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 14
Ultimi 30 giorni: 80
Tutti i Tempi: 1,310
