Salta al contenuto principale
Turtle Beach Ear Force XO Seven Slide Adjustment Replacement
Cosa ti serve
  1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: passo 1, immagine 1 di 2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: passo 1, immagine 2 di 2
    • Remove the two 1.0 cmTorx T6 screws using the matching Torx T6 screwdriver.
  2. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: passo 2, immagine 1 di 2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: passo 2, immagine 2 di 2
    • Insert the spudger into the gap between the leather and plastic.
    • After making sure you have a good grip, use the spudger to pry the two plastic pieces apart.
Conclusione
Altre 4 persone hanno completato questa guida.
Nancy Truong
Membro da: 01/30/15
375 Reputazione
2 Guide realizzate
Cal Poly, Team 17-36, Amido Winter 2015 Membro di Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 Membri
12 Guide realizzate
7 Commenti
What if the plastic part that connects the earphones to the headband breaks and is there a way I can fix or replace that ??
jamesfalduto - Replica
I really don't want to buy another turtle beach headset
James did you ever find a solution because I have the same problem
Commandcorps - Replica
Same problem here commandcorps.
adampm1 -
Same problem… plastic slide adjustment broke… contacted turtle beach and haven’t heard back… it should be an easy fix but can’t find the parts anywhere thus far…
Jim Davis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 4,296
