Salta al contenuto principale
Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement
Cosa ti serve
  1. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: passo 1, immagine 1 di 2 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: passo 1, immagine 2 di 2
    • The microphone is a separate piece. So, unplug it from the headset.
  2. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: passo 2, immagine 1 di 2 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: passo 2, immagine 2 di 2
    • Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone.
  3. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: passo 3, immagine 1 di 3 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: passo 3, immagine 2 di 3 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: passo 3, immagine 3 di 3
    • Now that the screw is removed, remove the slim metal plate at the base of the windscreen by gently pulling on the plate.
    • Then slide the windscreen off of the microphone.
Conclusione
Cal Poly, Team 17-36, Amido Winter 2015 Membro di Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,728
