Salta al contenuto principale
Turtle Beach Ear Force XO One Adapter Buttons Replacement
Cosa ti serve
  1. Turtle Beach Ear Force XO One Adapter Buttons Replacement, Adapter Buttons: passo 1, immagine 1 di 1
    • Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
    • The recommended screwdriver bit size is a PH 000.
  2. Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 2, immagine 1 di 1
    • Using your hands and/or a prying tool, carefully pry open the adapter.
    • This step may require a bit of force to complete.
    • Be aware that the adapter is held together with clips on the inside at some locations.
    • Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
  3. Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 3, immagine 1 di 3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 3, immagine 2 di 3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 3, immagine 3 di 3
    • Now, using the same Philips head screwdriver, unscrew the two screws on either side that hold the circuit board to the adapter case.
    • Once the screws are out, you can remove the circuit board from the casing.
  4. Turtle Beach Ear Force XO One Adapter Buttons Replacement: passo 4, immagine 1 di 1
    • Push the rubber piece containing the buttons out of the plastic adapter casing.
    • Then, replace it with a new one.
Conclusione
Joseph Lane
Membro da: 10/27/15
128 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 3-1, Shastany Fall 2015 Membro di UMass Dartmouth, Team 3-1, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G1
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,567
