Salta al contenuto principale
Turtle Beach Ear Force X12 Slide Adjustment Replacement
Cosa ti serve
  1. Turtle Beach Ear Force X12 Slide Adjustment Replacement, Slide Adjustment: passo 1, immagine 1 di 1
    • Remove the two 1.10 mm screws using the a T3 screwdriver.
  2. Turtle Beach Ear Force X12 Slide Adjustment Replacement: passo 2, immagine 1 di 3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: passo 2, immagine 2 di 3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tool into the gap between the fabric and the plastic.
    • Make sure you have a firm grip, use the plastic opening tool to pry the two plastic pieces apart.
    • Be careful not to crack or brake the plastic pieces.
    • You should have two plastic pieces removed at the end. Replace them with new ones and reassemble.
Conclusione
Katha Patel
Membro da: 10/02/17
218 Reputazione
2 Guide realizzate
USF Tampa, Team S1-G3, Thompson Fall 2017 Membro di USF Tampa, Team S1-G3, Thompson Fall 2017
USFT-THOMPSON-F17S1G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 538
