Introduzione
If your headphone system isn't providing quality sound through each speaker, it may be necessary to replace the speaker as it could be blown or an internal wiring issue. This replacement should take no longer than 30 minutes with the use of screwdriver and plastic pry tool.
Cosa ti serve
Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
Work circularly until removed.
Using metal prying tool, gently slide the tool between the speaker and the blue plastic holder to break up the adhesive.
Un commento
This is the first guide I've found that covers how the speaker is mounted to the plate. Thanks!
