Salta al contenuto principale
Turtle Beach Ear Force Stealth 500P Speaker Replacement
Cosa ti serve
  1. Turtle Beach Ear Force Stealth 500P Speaker Replacement, Earpad Assembly: passo 1, immagine 1 di 3 Turtle Beach Ear Force Stealth 500P Speaker Replacement, Earpad Assembly: passo 1, immagine 2 di 3 Turtle Beach Ear Force Stealth 500P Speaker Replacement, Earpad Assembly: passo 1, immagine 3 di 3
    • Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
    • Work circularly until removed.
  2. Turtle Beach Ear Force Stealth 500P Speaker Replacement: passo 2, immagine 1 di 2 Turtle Beach Ear Force Stealth 500P Speaker Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the four fastening screws that hold the blue plastic speaker mount in place.
    • Gently pull blue plastic from black housing by hand until separated.
  3. Turtle Beach Ear Force Stealth 500P Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Using metal prying tool, gently slide the tool between the speaker and the blue plastic holder to break up the adhesive.
  4. Turtle Beach Ear Force Stealth 500P Speaker Replacement: passo 4, immagine 1 di 1
    • Depending on how much of the adhesive was able to be removed, you should be able to pry up the speaker assembly using plastic pry tool. If unsuccessful, use metal tool by gently working around speaker using small twisting motions until free.
  5. Turtle Beach Ear Force Stealth 500P Speaker Replacement: passo 5, immagine 1 di 2 Turtle Beach Ear Force Stealth 500P Speaker Replacement: passo 5, immagine 2 di 2
    • Using wire cutters, cut the red and black wires connecting the speaker to the circuit board. Be careful to leave at least one inch of wire to use reconnect wires to new speaker.
  6. Turtle Beach Ear Force Stealth 500P Speaker Replacement: passo 6, immagine 1 di 1
    • Use wire strippers to strip a portion of the rubber colored coating on the wires about a quarter inch long from both the wires connected to the circuit board and the two red and blacks wires connected to the new speaker.
  7. Turtle Beach Ear Force Stealth 500P Speaker Replacement: passo 7, immagine 1 di 1
    • Twist together the matching pairs of un-shielded copper wire (black on black and red on red) and cover with wire connectors to prevent shorting.
Conclusione
UMass Dartmouth, Team 2-3, Shastany Fall 2015 Membro di UMass Dartmouth, Team 2-3, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G3
3 Membri
10 Guide realizzate
Un commento
This is the first guide I've found that covers how the speaker is mounted to the plate. Thanks!
Michael Merrell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,563
