Salta al contenuto principale
Turning off the center dashboard displays
  1. Turning off the center dashboard displays, Turning off the center dashboard displays: passo 1, immagine 1 di 3 Turning off the center dashboard displays, Turning off the center dashboard displays: passo 1, immagine 2 di 3 Turning off the center dashboard displays, Turning off the center dashboard displays: passo 1, immagine 3 di 3
    • :Press and hold the CD/AUX button on the base model stereo head unit for 10 seconds.
    • A beep will sound.
    • The clock, radio display, and heating/cooling displays turn off. Console backlighting remains on. Their functions are still active: you can change channels, adjust climate control. The displays are simply disabled.
    • To turn the displays back on, repeat step 1.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
David Spalding
Membro da: 11/12/15
6.470 Reputazione
12 Guide realizzate
Un commento
Do you know which button is used to turn off display in second generation Acura TSX?
Vinod R - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 4,325
