Salta al contenuto principale
Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement
Cosa ti serve
  1. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement, Panel: passo 1, immagine 1 di 1
    • Flip the keyboard over.
  2. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement: passo 2, immagine 1 di 2 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the three JIS #1 screws from the back cover.
  3. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement: passo 3, immagine 1 di 2 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement: passo 3, immagine 2 di 2
    • Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
  4. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement: passo 4, immagine 1 di 1
    • Pull apart the two parts of the panel to expose the motherboard and keys.
  5. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement, Keys: passo 5, immagine 1 di 2 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement, Keys: passo 5, immagine 2 di 2
    • Use a plastic opening tool to pry off every key.
  6. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement: passo 6, immagine 1 di 3 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement: passo 6, immagine 2 di 3 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement: passo 6, immagine 3 di 3
    • The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove.
    • Pull these keys to the side and up.
  7. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Motherboard Replacement, Motherboard: passo 7, immagine 1 di 1
    • Now that the motherboard has been removed from the keyboard, you can put a new motherboard in place of your broken one.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 588
