Introduzione
This guide will show you how to replace the LED lights for the Tt Esports Poseidon keyboard.
Parti
Nessuna parte richiesta.
  1. Flip the keyboard over.
    • Flip the keyboard over.
  2. Remove the three JIS #1 screws from the back cover. Remove the three JIS #1 screws from the back cover.
    • Remove the three JIS #1 screws from the back cover.
  3. Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case. Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
    • Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Pull apart the two parts of the panel to expose the motherboard and keys.
    • Pull apart the two parts of the panel to expose the motherboard and keys.
  6. Use a plastic opening tool to pry off every key. Use a plastic opening tool to pry off every key.
    • Use a plastic opening tool to pry off every key.
  7. The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove. Pull these keys to the side and up. Pull these keys to the side and up.
    • The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove.
    • Pull these keys to the side and up.
  8. Since the LED lights are connected to every key, you will need to replace this whole part.
    • Since the LED lights are connected to every key, you will need to replace this whole part.
Conclusione
Altre 2 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 77
