Salta al contenuto principale
Troy-Bilt TB675 EC Air Filter Replacement
Cosa ti serve
  1. Troy-Bilt TB675 EC Air Filter Replacement, Air Filter: passo 1, immagine 1 di 1
    • Remove the air filter housing by turning the plastic screw counterclockwise with your hand.
  2. Troy-Bilt TB675 EC Air Filter Replacement, Remove the air filter that lays beneath the housing you removed in step 1: passo 2, immagine 1 di 1
    • Remove the air filter that lays beneath the housing you removed in step 1.
    • It is good practice to inspect your air filter for tears or other defects. If defects are found it is best to replace the air filter rather than to clean it.
  3. Troy-Bilt TB675 EC Air Filter Replacement: passo 3, immagine 1 di 1
    • Clean the air filter thoroughly by spraying compressed air through the filter.
    • Be sure to spray the compressed air away from you in order to prevent injury.
  4. Troy-Bilt TB675 EC Air Filter Replacement: passo 4, immagine 1 di 2 Troy-Bilt TB675 EC Air Filter Replacement: passo 4, immagine 2 di 2
    • Wipe all oil and water residue around the air filter casing with a paper towel or rag.
  5. Troy-Bilt TB675 EC Air Filter Replacement: passo 5, immagine 1 di 1
    • Place the air filter and air filter casing back in its original position.
    • Be sure the air filter and housing are lined up correctly.
  6. Troy-Bilt TB675 EC Air Filter Replacement: passo 6, immagine 1 di 1
    • Complete the maintenance by turning the screw clockwise with your hand until it is fully secured.
Linea Traguardo
Brian Hall
Membro da: 10/10/14
110 Reputazione
1 Guida realizzata
USF Tampa, Team 1-10, Donnelly Fall 2014 Membro di USF Tampa, Team 1-10, Donnelly Fall 2014
USFT-DONNELLY-F14S1G10
1 Membro
1 Guida realizzata
Un commento
I believe you may have missed the small detail of giving us a part #.
That would’ve been VERY helpful.
Mark Henry Cooney - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,439
