Salta al contenuto principale
Tristar Handmixer Gears Replacement
Cosa ti serve
  1. Tristar Handmixer Gears Replacement, Gears: passo 1, immagine 1 di 3 Tristar Handmixer Gears Replacement, Gears: passo 1, immagine 2 di 3 Tristar Handmixer Gears Replacement, Gears: passo 1, immagine 3 di 3
    • Remove all the screws with the spanner and Phillips screwdrivers.
  2. Tristar Handmixer Gears Replacement: passo 2, immagine 1 di 3 Tristar Handmixer Gears Replacement: passo 2, immagine 2 di 3 Tristar Handmixer Gears Replacement: passo 2, immagine 3 di 3
    • Take off the mixer heads.
    • Push the eject button to do so.
    • Put the mixer in mode 5.
    • Gently open the mixer.
    • The spring might jump loose!!
  3. Tristar Handmixer Gears Replacement: passo 3, immagine 1 di 3 Tristar Handmixer Gears Replacement: passo 3, immagine 2 di 3 Tristar Handmixer Gears Replacement: passo 3, immagine 3 di 3
    • Remove the eject button by carefully lifting it out.
    • Remove the cable holder using the Phillips screw driver.
    • Remove the screw holding the mode button.
    • Carefully lift out the electrical unit.
  4. Tristar Handmixer Gears Replacement: passo 4, immagine 1 di 2 Tristar Handmixer Gears Replacement: passo 4, immagine 2 di 2
    • Remove the locking rings from the back end of the gears.
    • Use 2 screwdrivers to apply force on both sides of the locking rings.
    • Lift the gears from encapsulant.
  5. Tristar Handmixer Gears Replacement: passo 5, immagine 1 di 1
    • Replace gears.
    • Reassemble the mixer.
    • Happy mixing!
Conclusione
Altre 2 persone hanno completato questa guida.
3 Commenti
where can I get replacement gears from?
lanz - Replica
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz -
On it now. Let's hope we don't need to buy Cheap-China-plastic. Ideal of course would be to find metal gears, that would last whole life (if not motor breaks).
I also need to find a manufacturer of cog drive train wheels, that could do custom made, tailored, because if you refurbish a vintage handmixer you need parts that are not manufactured or in circulation anymore.
Henry -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,750
