Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Tablet screens often get damaged, this guide will walk a user through the steps of replacing a damaged screen. It is important to be careful about damaging parts, as most pieces are fragile.
Parti
Nessuna parte specificata.
  1. Locate the indentation at the bottom of the device. Locate the indentation at the bottom of the device.
    • Locate the indentation at the bottom of the device.
  2. Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device.
    • Pull on the indentation and take off the casing of the device.
  3. Remove the faulty battery and insert a replacement in its slot. Remove the faulty battery and insert a replacement in its slot.
    • Remove the faulty battery and insert a replacement in its slot.
  4. Remove the six 2.4 mm, Phillips #0 screws circled in the image.
    • Remove the six 2.4 mm, Phillips #0 screws circled in the image.
  5. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Remove inner casing exposing the motherboard.
    • Remove inner casing exposing the motherboard.
  7. Remove speakers by peeling back yelllow tape. Remove speakers by peeling back yelllow tape.
    • Remove speakers by peeling back yelllow tape.
  8. Remove ribbon cable on top of motherboard.
    • Remove ribbon cable on top of motherboard.
  9. Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
    • Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
  10. Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
    • Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
  11. Verify that all screws are detached from screen.
    • Verify that all screws are detached from screen.
  12. Detach screen from main assembly.
    • Detach screen from main assembly.
Conclusione
Stewart Jenkins
Membro da: 26/03/2018
207 Reputazione
1 Guida realizzata
IUPUI, Team S1-G1, Harley Spring 2018 Membro di IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
7 Membri
6 Guide realizzate
How can I do step 5? Do i need to push on the rectangle slots? It’s not very descriptive.
Nick “Blue” Wong - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 104
