Salta al contenuto principale
Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
Cosa ti serve
  1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: passo 1, immagine 1 di 1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: passo 2, immagine 1 di 1
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: passo 3, immagine 1 di 1
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the first layer of tape above camera cable connection slowly.
  5. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: passo 5, immagine 1 di 1
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 1-4, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 418
