Salta al contenuto principale
Trio Stealth G2 Hype Back Panel Replacement
Cosa ti serve
  1. Trio Stealth G2 Hype Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 Trio Stealth G2 Hype Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Back Panel Replacement: passo 2, immagine 1 di 1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Back Panel Replacement: passo 3, immagine 1 di 3 Trio Stealth G2 Hype Back Panel Replacement: passo 3, immagine 2 di 3 Trio Stealth G2 Hype Back Panel Replacement: passo 3, immagine 3 di 3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
Conclusione
USF Tampa, Team 4-4, Brown Winter 2015 Membro di USF Tampa, Team 4-4, Brown Winter 2015
USFT-BROWN-W15S4G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 667
