Salta al contenuto principale
Trio STEALTH-9 Motherboard Replacement
Cosa ti serve
  1. Trio STEALTH-9 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the two Phillips #00 screws on the side of the tablet.
  2. Trio STEALTH-9 Motherboard Replacement: passo 2, immagine 1 di 1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
  3. Trio STEALTH-9 Motherboard Replacement: passo 3, immagine 1 di 1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
  4. Trio STEALTH-9 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
  5. Trio STEALTH-9 Motherboard Replacement, Battery: passo 5, immagine 1 di 1
    • With the cover removed, slowly pull the electrical tape away as shown.
  6. Trio STEALTH-9 Motherboard Replacement: passo 6, immagine 1 di 1
    • Slowly pull the Battery away from the tablet frame.
  7. Trio STEALTH-9 Motherboard Replacement: passo 7, immagine 1 di 1
    • Prepare your Soldering Iron and Removal Tools.
    • Contact the iron with each of the battery leads, and pull the lead away from the board.
    • Remove any excess solder as needed.
  8. Trio STEALTH-9 Motherboard Replacement: passo 8, immagine 1 di 1
    • To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
    • Apply heat and solder to each lead individually.
    • Remove any excess solder if flooding occurs.
  9. Trio STEALTH-9 Motherboard Replacement, Camera: passo 9, immagine 1 di 2 Trio STEALTH-9 Motherboard Replacement, Camera: passo 9, immagine 2 di 2
    • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
  10. Trio STEALTH-9 Motherboard Replacement: passo 10, immagine 1 di 2 Trio STEALTH-9 Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
  11. Trio STEALTH-9 Motherboard Replacement: passo 11, immagine 1 di 2 Trio STEALTH-9 Motherboard Replacement: passo 11, immagine 2 di 2
    • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
    • Remove the camera from the frame and replace as needed.
  12. Trio STEALTH-9 Motherboard Replacement, Speaker: passo 12, immagine 1 di 1
    • Slowly remove the electrical tape holding down the Speaker wires.
  13. Trio STEALTH-9 Motherboard Replacement: passo 13, immagine 1 di 2 Trio STEALTH-9 Motherboard Replacement: passo 13, immagine 2 di 2
    • Remove the #00 screw on the Speaker mount and remove the Speaker mount.
  14. Trio STEALTH-9 Motherboard Replacement: passo 14, immagine 1 di 1
    • Prepare your Soldering tools. Desolder the Speaker leads from the Motherboard.
    • Remove any excess solder as necessary, and apply new solder when replacing a Speaker.
  15. Trio STEALTH-9 Motherboard Replacement, Motherboard: passo 15, immagine 1 di 1
    • Prepare your Desoldering Tools. Remove the grey wire attached to the Motherboard.
  16. Trio STEALTH-9 Motherboard Replacement: passo 16, immagine 1 di 3 Trio STEALTH-9 Motherboard Replacement: passo 16, immagine 2 di 3 Trio STEALTH-9 Motherboard Replacement: passo 16, immagine 3 di 3
    • Remove the three #00 Screws holding down the Motherboard.
  17. Trio STEALTH-9 Motherboard Replacement: passo 17, immagine 1 di 2 Trio STEALTH-9 Motherboard Replacement: passo 17, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of Tweezers to carefully pull the side buttons away from the frame.
    • Use the same Tweezers to carefully pull the microphone away from the front of the frame.
  18. Trio STEALTH-9 Motherboard Replacement: passo 18, immagine 1 di 3 Trio STEALTH-9 Motherboard Replacement: passo 18, immagine 2 di 3 Trio STEALTH-9 Motherboard Replacement: passo 18, immagine 3 di 3
    • Use your fingernails or a plastic opening tool to remove any remaining ribbon cables from the Motherboard.
  19. Trio STEALTH-9 Motherboard Replacement: passo 19, immagine 1 di 1
    • With the cables removed, lift the Motherboard off of the frame.
    • Repair or replace the Motherboard as needed.
Conclusione
To reassemble your device, follow these instructions in reverse order while being careful with the electronics on your repaired/replaced Motherboard.
Altre 2 persone hanno completato questa guida.
Mei Liang
Membro da: 01/29/15
228 Reputazione
2 Guide realizzate
Clemson, Team 15-5, Shirley Winter 2015 Membro di Clemson, Team 15-5, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 605
