Salta al contenuto principale
Trio AXS 3G Speaker Replacement
Cosa ti serve
  1. Trio AXS 3G Speaker Replacement, Back Case: passo 1, immagine 1 di 1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Speaker Replacement: passo 2, immagine 1 di 2 Trio AXS 3G Speaker Replacement: passo 2, immagine 2 di 2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Speaker Replacement: passo 3, immagine 1 di 1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
  4. Trio AXS 3G Speaker Replacement, Speaker: passo 4, immagine 1 di 1
    • Unscrew the two 4 mm #000 screws.
  5. Trio AXS 3G Speaker Replacement: passo 5, immagine 1 di 1
    • Use a soldering iron to desolder the speaker connection.
    • Be careful not to melt the wires.
  6. Trio AXS 3G Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the speaker.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 165
