Salta al contenuto principale
Triace A310 Disk Brake Replacement
Cosa ti serve
  1. Triace A310 Disk Brake Replacement, Tire: passo 1, immagine 1 di 1
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Disk Brake Replacement: passo 2, immagine 1 di 2 Triace A310 Disk Brake Replacement: passo 2, immagine 2 di 2
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Disk Brake Replacement: passo 3, immagine 1 di 2 Triace A310 Disk Brake Replacement: passo 3, immagine 2 di 2
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Disk Brake Replacement, Disk Brake: passo 4, immagine 1 di 1
    • Place the tire flat on the ground making sure the disk is facing you.
  5. Triace A310 Disk Brake Replacement: passo 5, immagine 1 di 3 Triace A310 Disk Brake Replacement: passo 5, immagine 2 di 3 Triace A310 Disk Brake Replacement: passo 5, immagine 3 di 3
    • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
    • Make sure to keep track of all of the removed pieces.
  6. Triace A310 Disk Brake Replacement: passo 6, immagine 1 di 2 Triace A310 Disk Brake Replacement: passo 6, immagine 2 di 2
    • After all of the screws have been removed, take the disk and pull it away from the tire.
Conclusione
Daniel
Membro da: 01/27/14
222 Reputazione
2 Guide realizzate
Cal Poly, Team 1-37, Maness Winter 2014 Membro di Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 643
