Salta al contenuto principale
Trek Neko Bike Brake Pad Replacement
Cosa ti serve
  1. Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: passo 1, immagine 1 di 2 Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: passo 1, immagine 2 di 2
    • Squeeze the two brake arms together.
    • Angle the brake noodle down.
    • Push the quick release down to release the brake noodle.
  2. Trek Neko Bike Brake Pad Replacement: passo 2, immagine 1 di 1
    • Flip the bike over so that the seat is on the ground.
  3. Trek Neko Bike Brake Pad Replacement: passo 3, immagine 1 di 3 Trek Neko Bike Brake Pad Replacement: passo 3, immagine 2 di 3 Trek Neko Bike Brake Pad Replacement: passo 3, immagine 3 di 3
    • Open the quick release lever on the bike wheel.
    • Rotate the lever in a counter clockwise direction to loosen the wheel.
    • Remove the wheel from the bike frame.
  4. Trek Neko Bike Brake Pad Replacement: passo 4, immagine 1 di 2 Trek Neko Bike Brake Pad Replacement: passo 4, immagine 2 di 2
    • Loosen the locking bolt on the brake pad with a 5 mm Allen wrench.
    • Remove the locking bolt, washers, and brake pad from the brake pad housing.
  5. Trek Neko Bike Brake Pad Replacement: passo 5, immagine 1 di 2 Trek Neko Bike Brake Pad Replacement: passo 5, immagine 2 di 2
    • Insert the new brake pad.
    • Insert the washers.
    • Insert the locking bolt.
  6. Trek Neko Bike Brake Pad Replacement: passo 6, immagine 1 di 2 Trek Neko Bike Brake Pad Replacement: passo 6, immagine 2 di 2
    • Tighten the brake pad locking bolt bolt clockwise until it is finger tight.
    • Tighten the bolt with a 5 mm Allen wrench.
  7. Trek Neko Bike Brake Pad Replacement: passo 7, immagine 1 di 3 Trek Neko Bike Brake Pad Replacement: passo 7, immagine 2 di 3 Trek Neko Bike Brake Pad Replacement: passo 7, immagine 3 di 3
    • Reinsert the wheel.
    • Tighten the bolt on the wheel until it is finger tight.
    • Center the wheel in the frame.
    • Close the quick release lever to secure the wheel.
  8. Trek Neko Bike Brake Pad Replacement: passo 8, immagine 1 di 2 Trek Neko Bike Brake Pad Replacement: passo 8, immagine 2 di 2
    • Place the bike right side up.
  9. Trek Neko Bike Brake Pad Replacement: passo 9, immagine 1 di 3 Trek Neko Bike Brake Pad Replacement: passo 9, immagine 2 di 3 Trek Neko Bike Brake Pad Replacement: passo 9, immagine 3 di 3
    • Insert the brake noodle into the quick release lever.
    • Angle the quick release lever upwards so that the brake noodle clicks into place.
  10. Trek Neko Bike Brake Pad Replacement: passo 10, immagine 1 di 2 Trek Neko Bike Brake Pad Replacement: passo 10, immagine 2 di 2
    • Squeeze the brakes to check proper fitment.
    • Tighten or loosen the quick release bolt on the brake arms to adjust based on preference.
Conclusione
With properly installed brake pads, you can now safely ride your bike!
Altre 2 persone hanno completato questa guida.
Camille Nikaido
Membro da: 02/02/23
181 Reputazione
1 Guida realizzata
UC Davis, Team 1-9, Andersen Winter 2023 Membro di UC Davis, Team 1-9, Andersen Winter 2023
UCD-ANDERSEN-W23S1G9
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 304
