Salta al contenuto principale
Trek 820 Light Mount Replacement
Cosa ti serve
  1. Trek 820 Light Mount Replacement, Light Mount: passo 1, immagine 1 di 2 Trek 820 Light Mount Replacement, Light Mount: passo 1, immagine 2 di 2
    • Clean the area where the light mount will be installed with a soft cloth.
    • Placing the light mount close to the center stem.
  2. Trek 820 Light Mount Replacement: passo 2, immagine 1 di 1
    • Remove the strap from the light mount fitting.
    • Stretch the strap clockwise around the handlebars.
  3. Trek 820 Light Mount Replacement: passo 3, immagine 1 di 1
    • Slide the strap through the slot and fasten to a snug, but moveable fit.
    • Do not fasten too tight as this will make it difficult to fine tune light mount placement.
  4. Trek 820 Light Mount Replacement: passo 4, immagine 1 di 1
    • Pull the strap tightly through the clasps at the bottom of the mount.
  5. Trek 820 Light Mount Replacement: passo 5, immagine 1 di 2 Trek 820 Light Mount Replacement: passo 5, immagine 2 di 2
    • Place the fastening screw in the rear screw port on the light mount.
    • Twist the screw clockwise using your hands until fully fastened.
Conclusione
Now you have a light mount ready for safer night rides on your Trek bicycle!
Cal Poly, Team 1-1, Propen Fall 2012 Membro di Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 865
