Salta al contenuto principale
Trek 820 Handlebars Replacement
Cosa ti serve
  1. Trek 820 Handlebars Replacement, Handlebar and stem: passo 1, immagine 1 di 2 Trek 820 Handlebars Replacement, Handlebar and stem: passo 1, immagine 2 di 2
    • Use a 3/16" Allen Wrench to remove the silver cap.
  2. Trek 820 Handlebars Replacement: passo 2, immagine 1 di 1
    • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
  3. Trek 820 Handlebars Replacement: passo 3, immagine 1 di 2 Trek 820 Handlebars Replacement: passo 3, immagine 2 di 2
    • Remove the handlebar by lifting vertically away from the frame.
    • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
  4. Trek 820 Handlebars Replacement: passo 4, immagine 1 di 2 Trek 820 Handlebars Replacement: passo 4, immagine 2 di 2
    • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
    • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
  5. Trek 820 Handlebars Replacement: passo 5, immagine 1 di 1
    • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
    • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
    • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
Conclusione
Cal Poly, Team 1-1, Propen Fall 2012 Membro di Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Membri
9 Guide realizzate
1Commento della guida
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 32
Tutti i Tempi: 6,378
