Salta al contenuto principale
Traxxas Summit Steering Assembly Servo Replacement
Cosa ti serve
  1. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: passo 1, immagine 1 di 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: passo 1, immagine 2 di 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: passo 1, immagine 3 di 3
    • Remove each of the four pins that hold the shell by pulling them from the posts.
  2. Traxxas Summit Steering Assembly Servo Replacement: passo 2, immagine 1 di 2 Traxxas Summit Steering Assembly Servo Replacement: passo 2, immagine 2 di 2
    • Remove the shell by grabbing it with both hands and lifting upwards.
  3. Traxxas Summit Steering Assembly Servo Replacement: passo 3, immagine 1 di 2 Traxxas Summit Steering Assembly Servo Replacement: passo 3, immagine 2 di 2
    • Disconnect the battery from the device by pulling the black plastic connector apart.
  4. Traxxas Summit Steering Assembly Servo Replacement: passo 4, immagine 1 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 4, immagine 2 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 4, immagine 3 di 3
    • Disconnect the four power cables that connect the motor to the electronic speed control.
    • Grab the connectors by their rubber covered metal ends rather than the wire if possible.
  5. Traxxas Summit Steering Assembly Servo Replacement: passo 5, immagine 1 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 5, immagine 2 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 5, immagine 3 di 3
    • Unscrew the single 15.5mm long retaining bolt from the motor with the 3mm hex key.
    • Remove the motor by wiggling back and forth while pulling it to the right and up.
  6. Traxxas Summit Steering Assembly Servo Replacement: passo 6, immagine 1 di 2 Traxxas Summit Steering Assembly Servo Replacement: passo 6, immagine 2 di 2
    • Flip the car on its back to provide access to the steering assembly.
  7. Traxxas Summit Steering Assembly Servo Replacement: passo 7, immagine 1 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 7, immagine 2 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 7, immagine 3 di 3
    • Unscrew the servo arm from the steering assembly by removing the 16.3mm long screw with a 2mm hex key.
    • Pull the connecting linkage out of the steering horn.
  8. Traxxas Summit Steering Assembly Servo Replacement: passo 8, immagine 1 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 8, immagine 2 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 8, immagine 3 di 3
    • Flip the car back upright.
    • Remove the two 7mm long screws retaining the largest wiring cover with the 2mm hex key.
    • Take the largest wiring cover off.
    • Remove the two 7mm long screws retaining the smaller wiring cover with the 2mm hex key.
  9. Traxxas Summit Steering Assembly Servo Replacement: passo 9, immagine 1 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 9, immagine 2 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 9, immagine 3 di 3
    • Remove the second wiring cover.
    • Pull the servo connecter out of the receiver.
    • Work the cable out of the receiver box.
  10. Traxxas Summit Steering Assembly Servo Replacement: passo 10, immagine 1 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 10, immagine 2 di 3 Traxxas Summit Steering Assembly Servo Replacement: passo 10, immagine 3 di 3
    • Remove the four 9mm long screws that retain the faulty steering servo with the 2.5mm hex key.
    • Pull the servo out.
    • Turning the servo horn by hand may be necessary to fit it through the hole.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,297
