Introduzione
If your R.C. Traxxas Stampede 12T Brushed Motor fails, is becoming worn out, or you would like to upgrade to a new motor, use this guide to help you follow the steps to remove the motor. Try to keep in mind you will want to start this project in an area where you won’t lose parts and screws. Away from any water, and in a well lit area. Make sure to have the truck turned off before attempting to remove any parts.
Cosa ti serve
Remove the fastner clips on all four corners of the body.
